  • SN95 4.6L Mustang Tech
I'm Baffled..Car starting problems
  • Thread starter Thread starter MrGame
  • Start date Start date Feb 28, 2007
MrGame
52
  • Feb 28, 2007
Well now that i've fixed the cam position sensor and reset the code in the computer, the car won't start unless I'm hitting the gas and if I don't it turns and then 'pops' and shuts off. After reading the other thread, I think it may be the IAC, but it stays running after I let off the gas if i can get it to start. Any ideas?
DTNODYA
831
  • Mar 1, 2007
Have you checked your fuel pressure to make sure that your pump is working correctly? Just a thought ....
the98stang
2,408
Clovis, CA
Mar 1, 2007
  • Mar 1, 2007
Clogged fuel filter?
MrGame
52
  • Mar 1, 2007
how do you check your fuel pressure? because I had my suspicions about that too
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Mar 1, 2007
  • Mar 1, 2007
Mr Game, I don't know about your previous thread, but by any chance were you getting codes P0340 or P0344?
The CMP (camshaft postion sensor) is used to correctly time the firing (pulsing) of the fuel injectors. If you have the variable reluctance type CMP sensor(2 wire non gear driven), and the CMP sensor did not correctly pick up the cylinder sequence right away, the PCM will abandon the sequential injector firing sequence and fall back on a batch fire injector table. This means the injector is just blindly fired once for every 2 revolutions of the crank. This can cause starting and running problems obviously. The COP's are also fired by using the CMP input as part of the ignition timing strategy.
MrGame
52
  • Mar 2, 2007
it was definately one of those two codes laserred you're the man! can that problem be fixed though? i took the car to the dealer because I got frustrated..I'm learning how to fix cars, but i'm not quite an A+ mechanic yet
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Mar 2, 2007
  • Mar 2, 2007
Based upon my experience, 9 times out of 10, those two codes point to a bad alternator, or an alternator on the way out. The low voltage will trigger the CMP codes, but there is likely nothing wrong with the CMP sesnor at all.
Brute03
232
  • Mar 8, 2007
i remember that P0340 code by heart now, it gave me such a headache. it took me a month and two cmp sensors to figure out that it was the alternator
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
