rdksek844
I had the exact same problem about a month ago and what it ended up being was a combination of two things. 1 was there was a yellowish film holding the butterfly open about .010" from being closed. I also noticed the gas pedal would stick a little when i went to press on it with my foot. 2 one of my butterfly screws had stripped out and my butterfly was not able to close all the way. I would remove the tb and clean it out, then remove you iac and clean around the plunger with tb cleaner and qtips. If that doesnt work try adjusting the tp voltage to .97 volts. I highly recommend not drilling the butterfly until a last resort. Just my .02. Hope this helps.
