Stangfreak95 said:My bottle has been in the car for a week of hot temperature. When I turned the valve on, the pressure was a like 1200+psi which is not good. Now I'm wondering..Is this because they overfilled the bottle or is it because of how hot it was in the trunk ?
Anyway, I took the bottle out and I'll leave it in the house to see if it changes when I put it back in. If not, I'll have to empty it till I reach the manufacturer's specs. ( I got a safety pressure valve and I dont want it to blow because the bottle is overfilled). And you got to spray between 900-1150psi. The bottle filled is suppose to weight 24.5pds. I weight it here (not sure if my scale is good) and it weights 25-26pds.
It just starting rainning so if it's dry later on, I'll test it tonight. Sucks. I really wanted to run it now !
Stangfreak95 said:Anyway, I took the bottle out and I'll leave it in the house to see if it changes when I put it back in. If not, I'll have to empty it till I reach the manufacturer's specs. ( I got a safety pressure valve and I dont want it to blow because the bottle is overfilled). And you got to spray between 900-1150psi. The bottle filled is suppose to weight 24.5pds. I weight it here (not sure if my scale is good) and it weights 25-26pds.
Boss 351 said:How far is the track from where you live? The tune is important so take your time. Good luck with it, sounds like it will be (or is) a hell of a beast!
Scott_B said:Was probably the heat! A guy i knew over-filled my bottle once! it was a Real hot day out, was in my apartment, heard my alarm go off, looked out, all i could see was N20 flowing out my sunroof and windows! Plus a hugh frozen spot on my rear hatch glass! Not good! Hope you have a down tube!
ANd the problem was the temperature in the trunk. The bottle was not overfilled. I weight it and it was dead on.SpencB said:Get the N/A 12's Bro and you get a free T
Like in Starsky & Hutch
"DO IT" "DO IT"
