I'm sad
  • Thread starter Thread starter 04GT
  • Start date Start date May 21, 2006
04GT
284
Southwest Ohio
May 21, 2006
  • May 21, 2006
Got my door blown off by a Mitsubishi Eclipse the other day. I don't know what it had in it, but it was making a weird noise. Maybe a turbo or nos...all I know is I was in 4th gear and he ran right past me. He was behind me in traffic, when the light turned green I went like normal, and by 4th, he was passing me. Not much I could do. I'd love to know what that guy had under the hood.
Dan_Soprano
7,410
54
129
Jacksonville, FL
May 21, 2006
  • May 21, 2006
oh well. there's always going to be someone faster. i'm sure there are some honda or mitsu's out there that could smoke my car. just haven't found one yet.
Cantslowdown
502
Mt.Home AR!
May 21, 2006
  • May 21, 2006
If you wasnt racing him then how can you say that you got blown away..Seems to me he was speeding..
fluffyrunnells
new hampshire
May 21, 2006
  • May 21, 2006
the weird noise was his girlfriend laughing at you...
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 21, 2006
  • May 21, 2006
A few months ago I got smoked by a Saturn Ion Redline
Mustang5L5
Mod Dude
Feb 18, 2001
43,345
18,074
224
Massachusetts
May 21, 2006
  • May 21, 2006
I get blown away all the time by people passing me at 30-40MPH that i am going while i'm cruising in 5th.
Was is an older eclipse? Those GSX's and GST's can be pretty damn quick cars.
CobraRed_96_GT
1,421
UCSD/La Jolla
May 21, 2006
  • May 21, 2006
well depending on which Eclipse it was this can make a lot of sence actually. The mid 90's eclipes has a GS a GST and a GSX the GST is turbo FWD and the GSX is turbo AWD. Both GST and GS weigh shortly upwards of 2700lbs where as your sporting over 3347 lbs.. W/ a substancial after market down pipe eclipses gain 2-3psi. including a flowing cat-back. It's not that hard to make rice rockets w/ potencial fast, now if it was the newer V6 eclipses, those are sleds u shoulda smoked it
hotmustang331
2,967
Bastrop,TX
May 21, 2006
  • May 21, 2006
My friend has a 90 talon (same thing really as eclipse) and it trapps 114 (24PSI)...and it was all jacked up and blowing out the spark in 3-4th. Im thinking @ 30PSI he could easily go over 120 in the 1/4. BTW he can easily turn it to 30.
But my friend has an aftermarket single turbo (like a 60trim) and different pistons. Otherwise its just exhaust work. (stock heads/cams/intake)
Anyways dont worry about it, those cars can be made FAST for CHEAP.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 21, 2006
  • May 21, 2006
DSM's can be NASTY for cheap money.. and that weird noise you heard was it's turbo, they come with one stock.
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
May 21, 2006
#10
  • May 21, 2006
  • #10
Who cares, man? You drive a legend. He drives an over-engineered bitch car.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
May 21, 2006
#11
  • May 21, 2006
  • #11
tomustang
Psychotic Member
3,434
McLean Hospital
May 21, 2006
#12
  • May 21, 2006
  • #12
04GT said:
I'd love to know what that guy had under his skirt
fix.t
04GT
284
Southwest Ohio
May 21, 2006
#13
  • May 21, 2006
  • #13
I wasn't racing the guy, just took off like normal shifting around 4K. When I saw him overtaking, I stepped on it. By the time I reacted, it was probably too late.
It just surprised me, b/c most of the ricers are all show.
gtstangau
133
Alabama
May 21, 2006
#14
  • May 21, 2006
  • #14
If you were crusing in traffic I would not consider that a race. There are some fast eclipses out there but for the most part they are slow as balls. I have owned a few mitsubishis and they are JUNK!
hotmustang331
2,967
Bastrop,TX
May 22, 2006
#15
  • May 22, 2006
  • #15
tomustang said:
fix.t
Trying to do a little converting there Tom? We know thats what you would have been thinking, but trying to give peeps ideas .
Lets make this clear...NO CONVERTING ON THE FORUMS!
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
May 22, 2006
#16
  • May 22, 2006
  • #16
umm yeah. not suprising. coming from a dsm background, the 90-99 eclipse/talon/lasers (in fwd turbo and awd turbo trim, not the ****ty non-turbo crap), are by far the best car with the "money spend per power gained" ratio.
the 4g63 motor alone, without touching ANYTHING, can handle 23-25psi, and roughly 400-450hp depending on tuning. now stick in some arp studs and a better head gasket, and it can handle 30psi and 500hp with the right tuning.
i had a 1997 GST Spyder. the only reason i dont still have it, is 400hp+fwd=worthless, and the awd swap was out of my realm of abilities. mods included:
Evo 16g Turbo @ 20psi
SBR Cast Manifold (Ported to match turbo hotside)
Custom FMIC + Piping (By me)
550cc Injectors / 190lph Pump / DSMlink for tuning(the laptop program thats basically standalone)
intake / turbo-back exhaust (3")
act 2100 clutch kit
on the freeway, in 3rd gear, as soon as it reached 20psi the wheels just broke loose until they heated up so much theyd finally catch, and by then i was already in 4th and at about 115ish(3rd gear tops out at 105mph). the car was stupid fast, from a roll. from a stop, well, lets just say the car was fwd, and 1st-3rd were useless in anything over 1/2 throttle. i remembered cruising just to find LS1's and GT guys to tangle with, just so see their faces. and i did, many times, all of them met "yeah, its fast, but its still a 4 banger", some people are just sad. the saleen guy i raced one night, got so pissed after 3 runs and 3 losses, he went into oncoming traffic, after i had hit the brakes and coasted down to reasonable speeds, just to prove he is more "hardcore" or something.
then i got the stang and realized that even though the eclipse was way faster than my stang now, the stang is just so much more fun to drive, and even the ****tiest exhaust on a stang sounds better than the best 4banger exhaust. and getting sideways with a slight blip of the throttle owns.
GREENBIOCH
1,241
In an Igloo
May 22, 2006
#17
  • May 22, 2006
  • #17
One of the greatest Quotes of all time!
timeless2
Admin Dude
202
154
the Shadow Gallery
May 22, 2006
#18
  • May 22, 2006
  • #18
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
What is this noise?!
  • squirrel0420
  • Jul 3, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 4, 2025
horse sence
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
is my car dead
  • kenzo0315
  • Jun 30, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 8, 2025
kenzo0315
Crank no start, I’m stumped!
  • Seth Brogan
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 14, 2026
BossHorseGirl
