EMW150
As for the total timing, i'm running a Mallory Comp 9000, which is mechanical advanced. If i go out and set my total timing to about 34, how do i know base timing won't be all crazy?
The base timing really doesn't effect much. You want as much initial advance as you can run without having starting trouble. I run my timing locked out at 36 degrees with a MSD starter saver that only retards timing only if the rpms fall below 500 for cranking the engine over. Zero low speed drivability problems. If you have starting problems, you can try to recurve the dizzy. Being even two degrees off on total timing will make a huge difference in the power it makes. It's also really important to have max timing early. You should have max advance no later than about 2400 rpms. If the Mallory distributors are like the MSDs, they come from the factory with a really slow curve (heavy springs) which gives max advance too late so you lose alot of midrange power. Need to change them out for the lightest.
