ok here is my observations: i compared my MAF to a fox side by side, here goes.... the fox, indeed is much smaller physically, hole size. BUT its a straight through shot...no meter in the middle restricting its at the top, next if you look at a stock 94/95, its much larger, BUT it really only has 2 little half moon-type passages where air can flow, looking at them side by side, i would say that they probably flow the same, or the fox flows more...really...i couldent believe it, but look at em side by side. now, i put on a 65mm that i had from my explorer, it was ghetto rigged so i took it off, but it dident give me any notaceable power, however this was without a tune. i do agreee that i need a larger tb, but all im saying is that the maf is much more of a bottleneck then the tb. So, do you really think i NEED 24's? i would like to hold onto the 19's if i can, i should be ok....Next i was thinking, could i measure the voltage across the maf with a multi-meter and see if its pegging? what wires? thanks
