My car is throwing two codes and is detonating like a Mofo with regular gas. I put premium in, and the detonation stopped, so I know its detonation.
I got codes
327 - EGR valve position cirvuit below minimum voltage.
328 - EGR closed valve voltage lower than expected.
So its the EGR valve. I took it off and cleaned it out really well, its only 2 years old since it was replaced.
I can get a new valve for $70, but it does not come with the position sensor. The position sensor is $25.
Money is tight, I can afford both but I'll be flat broke. If I buy the sensor and need the valve, I've wasted 25.
Do those codes sound more like the position sensor? Like I said, the valve works fine, I used a screw driver to open and close it.
But the car still detonates. Can a faulty sensor cause detonation, or is it definitely the valve?
I got codes
Probably a good way to burn out the solenoid. Try this at your own discretion, and only for brief moments.
