In Search of... Rack and Pinion Info
  • Thread starter Thread starter jikelly
  • Start date Start date Apr 17, 2004
  • 3
First Prev 2 of 3 Next Last
9
96 DOHC Cobra
542
Cerritos, CA
Apr 22, 2004
#21
  • Apr 22, 2004
  • #21
chepsk8 said:
A ways back, we had a few GOOD threads about Rack & Pinion Steering here.
I had ALOT of fun develping that system, and the only drawback was the large turning circle.
How much difference was there in the turning circle?
chepsk8
2,203
Easton, PA
Apr 22, 2004
#22
  • Apr 22, 2004
  • #22
Made it about 1.5 times larger, only no yiceable in parking or slow turns.
skywalker
733
Pensacola, FL
Apr 22, 2004
#23
  • Apr 22, 2004
  • #23
That's 95% of my turning! lol I'm seriously considering Randall's Rack myself, but it'll have to wait until I return from PLC in august.
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
Apr 23, 2004
#24
  • Apr 23, 2004
  • #24
Flaming river sells rag joints to connect to the steering column. Hum, I wonder if I could use that and not have to mess with disasembling my column. They might be a good source for info. I wonder if I could talk them into using my car to prototype a Rack for the 71-73 mustangs. Just a thought.
bnickel
5,640
lubbock, texas
Apr 23, 2004
#25
  • Apr 23, 2004
  • #25
you might look at http://www.darkhorseracing.net/ brion has a tcp rack in his 71 race car maybe he could give you some pointers
burnout289
1,000
sun diego
Apr 24, 2004
#26
  • Apr 24, 2004
  • #26
anybody remember this old thread?
http://forums.stangnet.com/showthread.php?t=128170&page=1&pp=25
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
Apr 24, 2004
#27
  • Apr 24, 2004
  • #27
Yeah I looked at that one lots of info but all the pics are gone. Chepsk8 I hope I got my email box cleared out enough for you to send me that file let me know if your message gets kicked back and thanks again for all the help.
skywalker
733
Pensacola, FL
Apr 24, 2004
#28
  • Apr 24, 2004
  • #28
hey cheap sk8, send your article to me too, gtg312a@prism.gatech.edu
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
May 4, 2004
#29
  • May 4, 2004
  • #29
I finally got around to measuring the steering components on my 73 and I wanted to ask you guys about something.
The crossmember that runs under the oilpan on my mustang is a solid piece and an integral part of my shock towers. That being the case I will not be able to make my own crossmember to mount in its place and am nervous about modifying it.
The center link is located about 2.5 inches away from the crossmember so I was thinking that that might not leave enough room to mount the rack on the crossmember anyway.
bnickel
5,640
lubbock, texas
May 5, 2004
#30
  • May 5, 2004
  • #30
on the darkhorse car the crossmember was completely cut out and he built a new one to mount the rack. i have looked at www.speeddirect.com and the way they are mounting the cavalier rack with tie rods in front of the rack instead of the normal modifications to place them behind the rack and i think that may work for your application pretty well, since the rack would not interfere with the cross member. on the actual cavalier application the rack is mounted on the firewall with tie rods in front. if you have enough clearance between the transmission and the factory crossmember it should work pretty well. i believe the late model monte carlos use the same type of rack as well so that might be another option
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
May 10, 2004
#31
  • May 10, 2004
  • #31
Okay so now that I am free from school I can really devote my time to this project.
I need to know from you guys if you think it is better if I use a rack which has the tie rods attached at its ends or in its center.
I am looking around on the web and I am thinking that the 90 something dodge intrepid rack might be what I'm looking for. I would have to use a center link on that type rack, but they seem to be easy to find, and not very to expensive
ashford
485
fargo ND
May 10, 2004
#32
  • May 10, 2004
  • #32
if you feel like going crazy on you front end i got a link for you
http://www.stuart.iit.edu/students/2112/restoration/M2frontend.htm
bnickel
5,640
lubbock, texas
May 10, 2004
#33
  • May 10, 2004
  • #33
jikelly, do you have any more info on the dodge intrepid rack you mentioned?
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
May 10, 2004
#34
  • May 10, 2004
  • #34
I have only seen pictures of the intrepid rack. I am probably going to go to the junkyard tomorrow to see if I can find one and take some measurements. Really I should just do a search on the web I bet the specs for that rack are posted somewhere. I guess the important dimensions would be mount locations, overall length of the rack and diameter.
R
Ronstang
1,294
Houston Texas
May 10, 2004
#35
  • May 10, 2004
  • #35
The MOST important measurement is overall rack travel.....that is the biggie, get me one that has enough travel for lock to lock steering and I will create the kit to make it a drop in proposition.
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
May 11, 2004
#36
  • May 11, 2004
  • #36
So the rack's lock to lock travel should equal the travel of my steering gearbox?
R
Ronstang
1,294
Houston Texas
May 11, 2004
#37
  • May 11, 2004
  • #37
It is not the travel of the steering box but the overall travel of the steering. The asisest way to find that value (I haven't done it in years) is to put the car on jackstands and put a plumbbob on the centerlink. Turn the wheel to one side tit locks and make a mark on the floor where the plumbbob is...then turn the wheel all the way the other direction until lock and mark the floor again. The distance between these two marks is the total travel necessary to keep from losing turning radius. Good luck finding a rack with this amount of travel becuase I don't think it exists.
chepsk8
2,203
Easton, PA
May 11, 2004
#38
  • May 11, 2004
  • #38
an idea I considered was the Cavalier style rack, which had a moving block, and clamp the center-link to it. Rear steer, just get the steering column to it, while clearing exhaust & clutch!
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
May 11, 2004
#39
  • May 11, 2004
  • #39
Well I struck out at the yard. They didn't have any intrepids, but I did find a few cavaliers and another car the olds acheiva which also has the center take off rack. After looking for information about it on the web I discovered that the olds racks had problems and might not be worth using. The intrepid is still the one that I'm looking for. I did find an interesting site on the web.
http://www.mavalgear.com/UnisteerPower.html
This company can apperently construct a rack to meet anyones specs. I bet its not cheap but it might be something to look at.
9
96 DOHC Cobra
542
Cerritos, CA
May 11, 2004
#40
  • May 11, 2004
  • #40
So how much travel (lock to lock) is considered "good?"
  • 3
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech May 31, 2026
LILCBRA
