They are designed to function with the Demon carburetor choke linkage without any interference and require no modification of any kind.
rbohm said:i
6: weber carbs. these are the ultimate carbs you can put on any engine. they actually surpase everything but a good efi system, and even then they come close. the problem with these carbs is the number of adjustments that can be made(1000 adjustments and 999 of them are wrogn for your engine). once these carbs are set though, you have an engine that launches hard like a supercharged engine, and is efficient in a wide rpm range, more so than any fuel system except efi.
