Inertia Switch... HELP!
  • Thread starter Thread starter rustang87
  • Start date Start date Jan 17, 2006
R
rustang87
70
Sac
Jan 17, 2006
  • Jan 17, 2006
Is the inertia switch in the passenger Kick panel? I kind of droped the frame on to the jack stands a little fast... Now it will run... for a minute then starve and die... I also hit the FP cutoff in the trunk to reset it and it made no difference. I got the code 95, but that comes up when you convert from Speed density anyways... HELP! Any ideas...
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Jan 17, 2006
  • Jan 17, 2006
The Intertia switch switch is behind the driver side taillight.
Sounds like you hit it already though.
The computer is located in the passenger kick panel.
HISSIN50
34
129
Jan 17, 2006
  • Jan 17, 2006
Aaron is right. I would probe the fuel pump relay with your meter and note the values you get with:
The car off
and
The key on and pump priming.
Knowing what you are missing will help to get you up and running (the FP relay socket is like a 4 way stop in a road. Knowing what is absent tells you which road to travel down).
Good luck.
R
rustang87
70
Sac
Jan 17, 2006
  • Jan 17, 2006
Is the FP Relay that black box? What should the volt meter read if it is working properly? Key on engine off? I am clueless and very frustrated... Please spell it out for me... Thanks for the responce.
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Jan 17, 2006
  • Jan 17, 2006
yeah, what they said. dont need to read the same stuff over and over!
HISSIN50
34
129
Jan 17, 2006
  • Jan 17, 2006
The FP relay should be under the driver seat on your 87 (unless a MAF conversion from a 92+ donor vehicle moved the relay to the passenger side strut tower area).
With the key off, you should see one wire with 12 volts and the others are dead.
WIth the key on and priming, you would see 3 wires with 12 volts and one with ground.
And if there is an issue, then it will be some variant. Knowing what you actually see will tell us what to have you hunt down.
It should not be too hard to sort out, so dont get too frustrated.
Good luck.
Crank no start, I’m stumped!
  • Seth Brogan
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 14, 2026
BossHorseGirl
W
Help with 95 GT
  • waynewl34
  • Apr 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 5, 2025
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
D
94 GT cold start takes a long time cranking. Help!
  • DeanS
  • Aug 6, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 10, 2024
