Within this next year i will be starting either a 331 or 347 build with my dad. Im looking for a streetable combo that i'll be using as my daily driver with plenty of power to run mid 12's or better at the track on 315 nitto dr's. Im looking for good parts, but nothing that will break the bank because im on a college budget. So far, i'm looking at a stock block build 347, scat cast crank, scat 4340 i-beam rods, and scat forged pistons (its a rotating assembly from summit complete with rings and bearings). For heads im looking at AFR 185's, intake im looking at the Systemax, Eddy Performer II, and the TF R Series. I am still unsure if i wanna get a custom cam ground or an off the shelf cam, but i was looking at a few Comp and Lunati cams in the .510-.530 max lift range. Im looking to keep it at around 10.5:1 compression so i can run pump gas. Please help me with some parts ideas with this build such as the rotating assembly and cam. Im pretty set on the AFR's as i know they are a quality head, and many people run them and love them and im just gonna look all over and find the cheapest price on one of the above mentioned intakes because they are all very similar and all within a few HP of each other. Thanks guys. As much info as i can gain on stroker motors is what im looking for, as well as the perfect combo for the best value
