Info on my upcoming SCT tune needed
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Tune is scheduled for end of the month...operator stated he will get the A/f 12.4-12.6 from start to finish. Question is would this be optimal for an N/a setup? If I recall correctly the 12.6 was to be the wot ratio and 12.4 everywhere else.
Well stype thanks for the bump anyways!!
Dons...so you would consider this safe but resonable for a power curve? I do run 16* initial and summer temps here average 80-90 so IF these factors are important (not sure if they even matter)then would the above stated A/F be aggressive enough..or too rich?
Why is he setting it rich?It should make best power at 12.8-13.2 across. I tune my car from a low 13 and work its way down to a high 12 up top. But I make more power, run much more compression than you and I rev higher. It should make best power around 34* total timing.
Is he tuning part throttle and medium throttle too or only WOT? I tune all loads with my PMS.
I had to read this through a couple of times to get a feel for what he might have been describing. No idea what your setup is or how aggressive your cam is or what your compression ratio is.
What I think he's saying is that he want to keep your AFR between 12.6 and 12.8 from the bottom of the rev range to the top @ WOT. He's not talking about part power or idle settings. As eluded to above, those AFR settings are too rich for just cruising down city streets but are great for WOT. It's a nice safe ratio to be in.
I agree with GRN92LX that overall, that may be on the rich side for an N/A application but again... cam and compression will have allot to do with where exactly, the "sweet spot" in your AFR will be.
Richer = safer
Leaner = more power
Since it's a street car... and if I were the tuner... I'd tune it after it were good and warmed up with the hood closed and a fan blowing in through the front end. I'd tune the AFR for peak power @ WOT (no pinging) then add between .2 and .4 (richer) to the AFR @ WOT across the entire power band. That would leave you with a good compromise between max power output and safe tune with a little fudge factor built in for the occasional crappy gas.
I will take the info above and have a chat with him regarding it..not having a background in dyno tuning I go in blind..but with a little info in the back pocket from here helps me understand the basics of it.
I thought this was a good summary of a/f settings. I didn't write it, and don't remember where I found it now though.
6.0:1 Rich run limit
9.0:1 Low power, black smoke
11.5:1 Rich best torque
12.5:1 Safe best power
13.2:1 Lean best torque
14.7:1 Chemically ideal
15.5:1 Lean light load, part throttle
16.2:1 Best economy, part throttle
18:1 Lean run limit
jason
