injector caps..
  • Thread starter Thread starter stangster50
  • Start date Start date Mar 1, 2007
stangster50
129
cranston ri
Mar 1, 2007
  • Mar 1, 2007
say i cracked a couple of the little orange caps at the tip of the injectors... would it be cool to use them like this? what is the purpose of them? worst case?
if its not good.. ive heard of injector re-build kits.. where would i get one?
thanx in advance..
montegoman351
169
Mar 1, 2007
  • Mar 1, 2007
Not so good, I wouldn't recommend you use the injectors untill you get replacement caps. Go to eBay stores, Mr.Injector store, order you a rebuild kit. Replace all the o-rings, filters, spacers and caps.
http://cgi.ebay.com/ebaymotors/Fuel...88129712QQihZ009QQitemZ190088129712QQtcZphoto
I just got done rebuilding my 24lb'ers, and I rebuilt my 19lb'ers a long time ago. I am very pleased with the quality, and ease of rebuild.
302RollinHard
Columbus, OH
Mar 1, 2007
  • Mar 1, 2007
Great seller on ebay. I think you use a 10mm socket to press on the new caps.
montegoman351
169
Mar 1, 2007
  • Mar 1, 2007
yup
A
armyjon
29
  • Mar 1, 2007
i agree with everybody else tried to use injectors that had cracked caps not a good idea.
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Mar 2, 2007
  • Mar 2, 2007
Just posted this in another post, but if you boil the caps in water they snap right on without breaking, which happens a lot if you don't, trust me!
stangster50
129
cranston ri
Mar 2, 2007
  • Mar 2, 2007
does that go for installing new one too? or just old ones.. i just bought the ebay kit..
they cracked, taling them out from sitting in there for so long..
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • Mar 2, 2007
if you cant wait, just go to pep boys and get thier kits. thats what we did on my buddies car.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 2, 2007
  • Mar 2, 2007
The pintle caps hold the O ring in place and keep it from sliding off and into the manifold. If the correct pintle caps are used, they do not have any effect on the injector spray pattern.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit.. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
The pintle caps fit either injectors with a pin sticking out the injector end or 4 with more tiny holes in the injector end
Engine Light throttle miss
  • Dontknowchit
  • Jul 7, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
AeroCoupe
D
Fuel Explorer 19lb injector rebuild
  • diesel farmer
  • Feb 9, 2025
Fox 5.0 Mustang Tech Mar 3, 2025
diesel farmer
D
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
