injector question
  • Thread starter Thread starter bluidvl
  • Start date Start date Oct 17, 2005
bluidvl
63
delaware
Oct 17, 2005
  • Oct 17, 2005
i bought a 90 lx that was converted to a 5.0 it has a 75mm throtal body and a 75mm sensor mac headers and 2/1" pipes what size injectors should that set up have and how can i tell what injectors i have.the one's in are a yellowish brown color thanx
D
Daggar
3,902
  • Oct 17, 2005
You have 19 lb injectors and nothing in the combo you've listed suggests that you require anything more.
bluidvl
63
delaware
Oct 17, 2005
  • Oct 17, 2005
thanx for the help do you think the censor and throtal body are to big
D
Daggar
3,902
  • Oct 17, 2005
your throttle body seem a bit large for your combo and could be making for some "lazy" air in your intake. The meter is fine so long as your bottom end drivability is good. Most meters these days have pretty good low end resolution regardless of the amount of air they're capable of metering up top.
bluidvl
63
delaware
Oct 17, 2005
  • Oct 17, 2005
thanx for the help.
I
IntenseBlue
946
  • Oct 17, 2005
Go to a 65mm throttle body.
bluidvl
63
delaware
Oct 18, 2005
  • Oct 18, 2005
what will the 65mm do for me
87gtconv
ragtopman
2,595
Southern Calif
Oct 18, 2005
  • Oct 18, 2005
For one thing it will have plenty of flow for your engine as it now is, and it wont be soft at the bottom end that the bigger TB just might be. With your mods the top end wont make up for the soft low end.
bluidvl
63
delaware
Oct 19, 2005
  • Oct 19, 2005
thanx for that info. the cars low end aint that great.high end feels preety good
BaXTeR3221
917
Orange County, NY
Oct 19, 2005
#10
  • Oct 19, 2005
  • #10
Ditto what these guys said, 65 or 70mm throttle would be better for the combo. Injectors are good until at least 300hp, so until you do H/C/I, you should be fine.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
