I have a 1994 Cobra that is having problems with the injectors. Car has a real bad idle. No Computer codes and On the Cylinder balance it brings up that the #6 has a problem. All plugs are nice and tan but the 6th plug and it is black. I swapped the injector, reset the computer and re-ran the test and same problem and the new plug is black again. What should the voltage to each injectors red power wire be at idle? Injectors 1-6 have from 1.7 volts to 3.2 volts, but the 7 and 8 have 12.5 volts at idle.
I unplugged the 7 and 8th injector and no change in idle at all. Is this a wiring problem? I then swapped injectors on 7 and 8 and they still have 12.5 volts. Is this the way that it is supposed to be? I also hooked up a noid light and ran the motor and on each the light is pulsing. ????
1994 cobra
rebuilt 302 ported gt40 heads and 2031 cam kit
24lb injectors stock maf and tb 1 5/8 lt and full exhaust
190 fuel pump and Has a lasota racing switch chip
I have now almost completely changed everything on this motor to find the cause of this bad idle.
On a full tank of gas and i got 198 miles. Car also has 373 gears. Friend mechanic told to me to get another injector harness, and there is no visible damage to harness right now.
Dunno what the problem is. ???
1994 cobra
