Changing the injector size on a stock or near stock engine will not increase the HP.
With the Speed Density computer, larger injectors will require you to either get a custom tune and have it retuned every time you add/change a component that changes the airflow through the engine. Components that change the airflow includes things like intake manifolds, cylinder heads and camshafts.
You will need to convert to Mass Air and either a custom tune or a MAF calibrated to match the injectors. Once installed, Mass Air adapts to changes in engine airflow due to changes in add-on equipment with no or minimal extra tuning.
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines.
Example:
19/.5 = 38, 38 x 8 = 304 HP
24/.5 = 48, 48 x 8 = 384 HP
30/.5 = 60, 60 x 8 = 480 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
304 HP x .85 = 258 HP
385 HP x .85 = 326 HP
480 HP x .85 = 408 HP
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
If you change the injectors, you will also need to change the fuel pump to provide sufficent fuel flow to keep from starving the injectors.
Safe “Horsepower Capacity” @ 40 PSI with 12 Volts
88 Liter Pump = 140 LB/HR X .9 = 126 LB/HR, Safe for 250 naturally aspirated Horsepower (stock pump size)
110 Liter Pump = 175 LB/HR X .9 = 157 LB/HR, Safe for 315 naturally aspirated Horsepower
155 Liter Pump = 246 LB/HR X .9 = 221 LB/HR, Safe for 440 naturally aspirated Horsepower
190 Liter Pump = 302 LB/HR X .9 = 271 LB/HR, Safe for 540 naturally aspirated Horsepower
255 Liter Pump = 405 LB/HR X .9 = 364 LB/HR, Safe for 700 naturally aspirated Horsepower
