injector size
crookman10
26
not sure if im going to need to upgrade injectors to #24 Im putting trick flow kit on heads, cam and upper and lower also plan on getting a c&l 75mm throttle body msd ignition and distributor already have a 190 lph fuel pump that came with car but never installed. im pretty sure ill need 24's also putting on spacer between intakes, this car is already maf (cali car). thanks
