Injector size ?
freddyk70
15
Bought 347 from acquaintance. Big victor alum heads, efi intake. Not sure of cam specs, he says it was 8.5:1 compression but I'm not sure he really knows.
Using a tool on Ford Motorsport website, I calculated 30# injectors running at 85% duty, but he had 24# in it (I didnt get injectors).
I got the car running. Good throttle response in neutral but it won't accelerate at all when the car is in gear, it just chokes and wants to die.
Should I go back to 24# injectors?
Having trouble reading KOER codes since no NSS, but going to try to cancel switch tonight.
I am running an Abaco DBX97 programmable mass air meter. I created the program file based on stock Ford computer with 30# injectors, using the Abaco software. I uploaded the program to the thing... hopefully it is correct but who the hell knows. It looks pretty tho!
I'm considering trying to pick up a different maf unit to at least eliminate that.
Right now I can't get many codes out of computer, getting only these 2:
66 MAF sensor went below 0.4 volts during the last 80 warm-up cycles
98 Hard fault
did you recalibrate the mass air meter for the 30 # injectors?
