leon_reynolds said:
Thanks for the info.......I was looking into getting a tweecer so i could calibrate myself when upgrades arrive. I didnt know anything about the anderson pms although they seem considerably more expensive. Does the tweecer do the same functions, or does the anderson have a better product? I do not care much about the ease of use, I would rather spend a little more time researching and learning then spending the additional money if accomplishes the same thing.
They are "different" products. It will totally depend on what your preferences are for their use as to which one you get.
Instances for what little I know about your combination:
42 lb injectors
MAF calibrated for 42s
Supercharger
The PMS is easy to use. You can add or subtract fuel at an portion of the RPM range as a percentage to bring your AFR up (or in your case down) to the appropriate level. The PMS will make use of BAR/MAP which makes it simple to add fuel based on a boost reference. There is not a huge learning curve required to make the PMS perform these functions
The TwEECer on the other hand, will give allot more control over engine tuning. It allows you to make modifactions to the MAF transfer curve (something that you do not necessarily require if your meter calibration is accurate). It allows modification of a HUGE number of scalers within the EEC. It can not make use of a BAR/MAP for boost referencing but instead require tune of the fuel ramps, spark tables, injector breakpoints, dapshot settings, and a host of other things to perfect the tune for the combo regardless of what that combo happens to be. The learning curve is very steep. It will require a considerable amount of time to learn and many hours spent on the forums to help figure out what does what and why.
My reason for thinking that the PMS would be better suited to your application comes down to your not needing to modify the MAF transfer curve. With a Tweecer you can use pretty much any meter. You would load the transfer function into the Tweecer then tell it what size your injectors are (there's a bit more to it than that but that's it in a nutshell). In your case, I think that it all be done a ton easier with and Anderson PMS.
Read through each of their forums and decide which one you think would work best for you. Then throw your hands up and say "screw it" and go out and get a custom chip and tune.
P.S. A custom tune and chip will cost your roughly $600 and another $100 for each for each subsequent tune after modifactions are made.
