  • SN95 4.6L Mustang Tech
injectors to big?
  • Thread starter Thread starter brian_23456
  • Start date Start date Aug 1, 2005
brian_23456
50
  • Aug 1, 2005
I am planning on putting a paxton novi 1000 with a Anderson powerpipe on my GT, and was looking at a used set of injectors. Would 50# injectors be too much if I plan on using the pulley that comes with the kit? I know most poeple use 42# injectors, but I would rather get these used ones if I could.
thanks
M
mac1009
187
Atlanta, GA
Aug 1, 2005
  • Aug 1, 2005
You can tune the car for the 50's. If at some point you decide to go for more, that's one less piece to buy.
brian_23456
50
  • Aug 1, 2005
thanks
50's it is!
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Aug 1, 2005
  • Aug 1, 2005
I agree. Good luck.
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Aug 1, 2005
  • Aug 1, 2005
you can use 50's, but you'll never use them to their potential with a Novi 1000. 42's are easier to tune from what i've heard.
Lons2001GT
75
  • Aug 1, 2005
I agree !
brian_23456
50
  • Aug 2, 2005
But they are at a really good price, also matched and flowed.
I won't be the one doing the tuning any ways
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 3, 2005
  • Aug 3, 2005
A set of 36lb injects would be more than enough for a Novi 1000's flow potential and keep things cleaner/smoother down in the lower RPM and at idle too. Sometimes bigger isn't always better my friend. Let these 50lbers go and mate that Novi up to a properly matched set of injectors.
brian_23456
50
  • Aug 3, 2005
36's you say?
So would 42's be too big also then?
I'm not planning on going over 400rwhp for quite a while by the way, maybe around 380rwhp.
M
mac1009
187
Atlanta, GA
Aug 3, 2005
#10
  • Aug 3, 2005
  • #10
42's would be fine. I'm right under 380 at the tires now, and the 42's are more than enough.
brian_23456
50
#11
  • Aug 3, 2005
  • #11
Would they be too much injector though?
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 3, 2005
#12
  • Aug 3, 2005
  • #12
No, 42's are not too much injector, but still overkill for your Novi needs. The rule to follow as far as injectors are concerned is using just enough to keep them within efficient operation range is best. You don’t want to see much more or less than 80% duty cycle which is what you’ll achieve at 330-380hp with 36lb/hr injectors (about where the Novi would put you with a few minor bolt ons). Any smaller injector may overwork the injector and with much more that that small things like emissions, idle quality and low end response suffer. 36's would work best, but 42's aren't that tremendous by comparison and will prove nearly as good in all but the most severe conditions (like high temp/humidity and elevation levels).
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
