a friend gave me some injectors that are brand new and they are pink colored the part number is fote-9f593-d9b what size would these be and are they for a mustang?
i tried to google but came up with nothing so they would not work with my car then right?i have an 88 motor and i plan on switching over to mass air i already have the harness .
when you say new edge you mean ford edge truck injectors?i go these for free from a friend and he has another set that are a different color maybe they are for a mustang.
They'll work fine. Most injectors are not application specific. As long as they're high impedance, fit the wiring harness and fit the manifold you can use them. Look at the injectors I'm using.
thanks never heard of the term new edge but i will try them out, if they don't work out i will get the other set he's got.i got these for free and my motor is mostly going to be stock except that i bought a upper and lower cobra intake .
Are your stock injectors bad? If not, the new pink injectors are the same as your stock 5.0 19# injectors, which are plenty fine for now with just an intake. Add some heads and a cam and you will want to step up to 24#+ injectors.
They are injectors out of a newer Mustang GT. The pink ones first appeared in 2003-2003. I beleive some late 02's got them as well.
I just checked the injectors on my '03 and they are the same as the part number you gave...which is strange because it's a 1990 Ford engineering part number..meaning they might have been used on something else
That's correct. The earlier new edge's, such as my previous 2000 GT, had orange squirters. They are both 19# injectors, although some debate that the pinks are 21-21.5#. But Randy, a member on here who is a ford parts counter guy, says they are 19#.
