- Sep 8, 2005
- 40
- 0
- 0
I polished my procharger, and while doing so, I noticed this pinhole in the casting. It's really small, will this present a major problem??
If it is actually a leak use some JB weld and let it sit for a while.NeverFastEngh said:If you score the metal around it well enough then JB weld would work. I have used it on alot of things you wouldnt think would work, but they all did.
FalconGuy016 said:A leak? I'm not sure what exactly the housing is related to in the operation of the supercharger but that sounds pretty catastrophic to me... I guess I'm not thinking of the same thing.
BennyBlown2v said:http://www.alumaloy.net/
Seriously. Or, a lil spot of tig will fix it. Fix it with metal, not JB weld - JB might hold but won't be a perminant fix.
That pin hole is in the part of the blower where the air goes out. If the hole was in the part where the gears are....THAT would be very, very bad. Where it is, at worst, it's just not going to hold boost (but should make a wicked cool whistle lol); but, if it were in the oiled side it would leak and pretty quickly kill the blower by starving it of oil.
KidCapri50 said:I got her tig welded today! Problem solved
Thanks for the input, it was either tig it or some bubble gum.
the98stang said:WTF..."alumaloy"?!![]()
I'd trust JB weld over that crap ANY day. Especially when it says "As seen on TV" LMFAO.
But really your best bet (with out okey riggin' it) is welding or replacing the housing.
blacksheep-1 said:It's actually leaking, like you can feel it? If so, then drilling and tapping might work, but what if the casting is thin in that area? it could make the problem worse. You might take it apart and have it welded, but that could warp the housing. The ultimate fix would be to replace the housing but thats $$$$.
I hate to say this, and to post it because I know I'll be slammed 6 ways to sunday, but........JB Weld
OK, I'm ducking now...................
