Car's had a steady, small, but annoying tranny fluid leak since I bought it. Got to the point that it finally glazed the clutch and made it slip under anything more than 50% throttle. Three days ago (and busting my butt for 10 hours straight) I put in a new King Cobra clutch kit, rear main seal, and input shaft seal. Made sure everything was torqued down evenly and to specs, drove in the seals nice n' straight (used a socket for the input shaft seal, and the old rear main to drive in the new one), cleaned all the old RTV off the bearing retainer and put on a nice, even bead of Ultra Copper RTV. Even gave it all a few hours to set up and cure before starting it and driving around.
Well, 50 miles later, the trans fluid leak's right back where it was - coming from the front of the tranny (bellhousing), leaving a little telltale drop or two wherever I park. I'm sooooo not happy that my new KC clutch is at risk of becoming crap after less than 100 miles.
Anyone know what could've gone wrong? The old seal I took out didn't look bad at all, actually, but that was directly where the leak was originating from. No cracks in the tranny case, either. Only thing I can figure is that maybe the (stock aluminum) bearing retainer is warped or something. I keep reading ads for the steel bearing retainers that "the old aluminum retainers will WEAR OUT." HOW?!? It's not a moving part, and the only true wear is on the bearing cup, cone, and seal that it houses. But if not that ... then what?
My car hates me. First the demonic possession, and now this...
