Inside door lock handle question
  • Thread starter Thread starter sparx
  • Start date Start date Apr 20, 2011
sparx
369
  • Apr 20, 2011
I successfully replaced the window regulator on my 66's drivers side today.
Not too difficult but some work has to be done blind as you know if you have done this.
I found another issue, in that the inside door lock handle does not spring back into the "home" position as does the passenger side. What drives the handle back, is it possible I am missing a spring somewhere?
Sparx
Problem solved!
robbz28
775
Epps, LA
Apr 20, 2011
  • Apr 20, 2011
Yup, a little bitty spring, im not promoting a site, but here is what you need...
DOOR LATCH SPRING STAINLESS STEEL 1967-1970 | CJ Pony Parts
If your handles are wobbly your can replace the whole assembly for like 15 bucks or so a side while you are at it.
sparx
369
  • Apr 20, 2011
Thanks Robbz
I have a 66.
Those are sold out so I may have to purchase the entire latch.
Jim
sparx
369
  • Apr 26, 2011
I got the problem solved by replacing the "Door Handle Shaft". This part contains the spring (in the back) that produces the force required to return the door lock handle to it's resting position.
Here is an image of the old part and the package from the new:
<a href="http://photobucket.com" target="_blank"><img src="http://img.photobucket.com/albums/v281/sparx21/Mustang%20Stuff/mustdoorhndlshaft.jpg" border="0" alt="Photobucket"></a>
robbz28
775
Epps, LA
Apr 26, 2011
  • Apr 26, 2011
Worth every penny
sparx
369
  • Apr 26, 2011
It sure fit nice and solved the problem. Hard to believe how many things are worn out on the car, but it is old.
sparx
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
1989 Passenger side electric window issue
  • Sanchez_005150
  • Jul 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
Fuel 87 5.0 Fuel rail lines
  • Mcmahst
  • Jan 21, 2025
Fox 5.0 Mustang Tech Feb 11, 2025
Mcmahst
Interior and Upholstery Inside door flex when window rolls up fully
  • beeduckworth
  • Sep 19, 2023
2K
Fox 5.0 Mustang Tech Sep 21, 2023
limp
