  • 2005 - 2009 Specific Tech
install help on axleback slp kit
  • Thread starter Thread starter flames201
  • Start date Start date Oct 30, 2005
flames201
77
st. amant, la
Oct 30, 2005
  • Oct 30, 2005
i am going to install the slp axleback kit for a friend this week. is it just a direct bolt on? it said 30 min. install ;but this will be my first on an 05.
G
gpp
137
  • Oct 30, 2005
figure a hour at least and thats on a lift.just have to take the muffler hangers off which is no big deal just takes time.
I
I8URVTEC
162
  • Oct 31, 2005
I'd say an hour too but most of that is just getting them lined up correctly. The stock axle back is held on by four bolts and one clamp per muffler. I am not sure how the SLP installs but most likely it will use the same hanging hardware. The four bolts that hang the mufflers are located above the muffler and basically just attach the hanging hardware to the body of the car. The clamp is what clamps the over axle pipes to the axle back. The best thing to do is jack up the rear end and put the rear end on jack stands. A lift would be ideal but jack stands should be all the clearence you will need. Here is a picture of my stock mufflers removed which I was able to do without even jacking the car up:
http://franksperformance.com/Forums/index.php?act=module&module=gallery&cmd=si&img=14
Hope that helps.
1fastz
124
  • Oct 31, 2005
your kiding right ?
took me 10 minits from teh time i lifted the car on the lift till the time i droped it back to the ground
there is four nuts to losen then you simpley slide the mufflers and pipes off and then reasemble in the reverse
ArchNemesis
171
San Diego CA
Oct 31, 2005
  • Oct 31, 2005
took me about an hour to install my Borlas and that was in my garage, with a jack, lifting each side separately, and taking a smoke break in between. took maybe 10 minutes to unbolt each side and slide on the mufflers, and they lined up perfectly the first time.
I
I8URVTEC
162
  • Oct 31, 2005
The actual unbolting and bolting them back up does take no time. I estimated an hour b/c it took some time and adjusting to get them lined up correctly again. Of course it could be different with SLPs. I had Bassani's
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Oct 31, 2005
  • Oct 31, 2005
the STOCK mufflers can be slip off the hangers. you just need to loosen the clamp bolt. FLOWMASTER a.b. kit has oposing hangers and you have to remove the hangers and put them on the mufflers before you install them. i dont know about SLPs, but if the hanger tabs are facing the same direction, then they would just slide on, but if they go different ways, then you have to pull the hangers as well. with the SLPs, it should be easy to tighten the hangers, because the pipe design is slim, compared to a muffler.....
stlwagon
15
Southern, MD
Nov 1, 2005
  • Nov 1, 2005
Took me about and hour to get the SLPs installed and lined up correctly. And that was without a lift or ramps. Knuckles paid the price for that move. Fit nice. EXTREMELY loud...
shooterm1
540
Milford, Pennsylvania USA
Nov 1, 2005
  • Nov 1, 2005
Does anyone have an extra pair of Stock GT Muffler hangers left over and lying around?
I sure could use them!
I
I8URVTEC
162
#10
  • Nov 1, 2005
  • #10
I tried my darndest to slip them out of the rubber grommets and just couldn't do it. Had to undo the four bolts and take the hangers off. There just didn't seem to be enough clearance to slip them out.
bigcat
May 1, 2005
3,015
7200 feet
Nov 1, 2005
#11
  • Nov 1, 2005
  • #11
mine came right out.....
bigcat
May 1, 2005
3,015
7200 feet
Nov 1, 2005
#12
  • Nov 1, 2005
  • #12
thats a tough one, you reuse the ones you have when you put on new exhaust, so finding an extra set will be difficult....
SixFivePony
248
Livermore, CA
Nov 1, 2005
#13
  • Nov 1, 2005
  • #13
Yep. It's super quick. Unbolt old stuff, bolt on new stuff. Done. Literally, nothing to it.
flames201
77
st. amant, la
Nov 2, 2005
#14
  • Nov 2, 2005
  • #14
it was a snap! way easier than the pro chamber install on my 04 gt!!! took all of 30min. very nice tips that came with the set.
thanks for the help!
I
I8URVTEC
162
#15
  • Nov 3, 2005
  • #15
Knew it shouldn't have given you a problem...how does it sound?
flames201
77
st. amant, la
Nov 3, 2005
#16
  • Nov 3, 2005
  • #16
loud and raspy, with some poping when u let off the gas. it's for a chick i know she likes it alot! so that's what matters most i guess.
M
Mike06_10pm
98
#17
  • Nov 4, 2005
  • #17
nvm
jlisle01
250
McAlester,OK
Nov 4, 2005
#18
  • Nov 4, 2005
  • #18
Damn straight!
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
C
Paxton novi 1200SL
  • Cambo617
  • Oct 9, 2025
2005 - 2009 Specific Tech Oct 9, 2025
Cambo617
C
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 26, 2025
D
2006 GT Windshield Cowl install
  • Daddidio
  • Mar 12, 2026
2005 - 2009 Specific Tech Mar 12, 2026
Daddidio
D
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
