INSTALLED ACCUFAB,75mm,CAI,& Predator???
I just took the car out after installing these parts and did not notice a whole lot of SOTP gains. Both the intake and 75mm are ACCUFAB and the CAI is the Demolet full lenght one. I was hoping for more pick-up :shrug: Maybe I should have held out for a S/C. Also anyone with the ACCUFAB stuff notice a slight whistle when you barely give it gas? Thanks
Definately woke mine up above 3K as well - that's when you can really notice the difference.
Mine doesn't whistle at all though...check all you connections again...something maybe loose or leaking and causing a loss in power.
I don't see gears in your sig. Your gains may not be as noticable as most who've done a gear swap, since you don't rip through the gears and reach the upper RPM as quickly.
With my P&Pd plenum I didnt notice a difference rightaway, but after a while I could tell that the car pulls pretty strong all the way to 5800 with not much drop off like it did before. I know torque is dropping, but the rpms pull right to 5800 without the feel or sound of the car loosing a ton of power.
Kilgore Trout said:
No, I asked that same question a couple months ago and many people said no... Will not lose the tune.
Correct. The tune is held in the same flash NVM (non-volatile memory) as the factory tune was. Disconnecting the battery will reset the PCMs learned parameters which are stored in different battery-backed RAM. Upon re-boot, the PCM will test that memory, see it's been "corrupted" and reset it to factory defaults. It provides essentially a "clean sheet of paper" for the PCM to re-learn. Ryan, you might find the idle is a bit wonky at first since closed loop idle control parameters are some of those that are held in battery-backed RAM. It'll figure it all out again...no worries.
