Installed LMAF
Guero
2,148
I finaly installed the LMAF today. Would it make my car run lean or rich after it put in on the MAF Transfer?? I feel like it made my car run lean, but i wanna make sure before i go really mess with it. Man i need a W/B!
If the transfer and inj. slopes are correct it should be close to what you have commanded in your fuel tables.
A quick way to "kinda" tell is to look at the K's the goal is to get them to be as close to 1 as possible (they will never actually be 1 though). If you see in the log they are at like .9998 or .9989 or something your probably really close. Just remember the K's do not really apply to WOT as the o2's do not adjust the fuel at WOT.
If your using a factory LMAF with the LMAF maftransfer you should be close as long as the inj. are also good.
