Installed my headlights
  • Thread starter Thread starter 5.0TailPipeHump
  • Start date Start date Feb 19, 2008
5.0TailPipeHump
153
Feb 19, 2008
  • Feb 19, 2008
Awhile back i made a thread if i should go smoked or clears and i went with clears and am really satified with the look,
it makes the car look alot more cleaner and gives it that wow effect!
The install was pretty easy and took about 1½ hours , the bolts on the top
part on the headlights were not fun taking off and putting back on.
Now i just need to adjust em and there good to go.
leroy93lx
29
Indiana
Feb 19, 2008
  • Feb 19, 2008
They look great! Mine were somewhat of a PITA to get adjusted, but i got it. I also got mine 4 or 5 years ago when they first came out, so maybe the quality got better over time. Hopefully you have no issues. Looks good though!
Foster9887GT
  • Feb 19, 2008
How Do you Adjust them? Are the Fog Lights Adjustable?........BTW, They look good, makes her look like new...
5.0TailPipeHump
153
Feb 19, 2008
  • Feb 19, 2008
There is adjusters on the back , my dad has the tool to do it , iv never adjusted headlights bf , the thing were gonna use is a hex shape unit, i belive its 4mm and that goes into the bolt thats purtruding, then turn it to the desired positioning.
seems not that hard. but were gonna line it up against a wall on a flat surface when its all said and done.
thanks for looking guys!
LB0193
171
IL
Feb 19, 2008
  • Feb 19, 2008
poor old notchy in the snow
5.0TailPipeHump
153
Feb 19, 2008
  • Feb 19, 2008
Lol you mean poor fella is in the house cant drive his notch till the snows gone.
I cant wait till this white crap turns into water and evaporates.
Kabuki_notch
670
394
113
Rochester, NY
Feb 19, 2008
  • Feb 19, 2008
amen
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Feb 19, 2008
  • Feb 19, 2008
looks great! good choice for sure.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 19, 2008
  • Feb 19, 2008
I drove around for several days with the driver’s side headlight scanning the upper branches of trees for squirrels, owls and UFO’s. The headlight lens had extra slack between the retaining clip and the screw head which allowed the lens to shift around. Fixed that with some small washers between the screw heads and the bottom of the mounting hole. I would recommend that you find 2 extra adjustment screws per side - they are the ones with the hex ends on the end of the screw where it sticks through the mounting plate. That may help the alignment problems, as the stock setup only allows adjustment with 2 screws, and is hard to adjust in and down at the same time.
If you bought Genuine Ford headlights, the adjustment will be easy. If you bought reproduction headlights, they will be very difficult to align properly. I bought reproduction units the first time, and my headlights could not be aligned: they would shine up in the trees and across the road. I even had all 3 screws set up as adjustment screws.
The set of headlights I now have say "Ford" on them and they seem to line up properly.
The adjustment screws are upper inside and lower outside screws. If the headlights were re-assembled properly, they will have a 5/32" hex on the screw. You can use a 1/4" ratchet with a 5/32" socket. The upper screws can be reached with the hood up, while the lower screws may require you to lay on the ground in front of the car and reach them from the bottom.
To align the headlights, find a level spot with a wall 25-30 feet away. Disconnect the driver light and align up the passenger light so that the light pattern is slightly below of the actual centerline of the headlight. This is to illuminate the right hand side of the road. Reconnect the driver light and disconnect the passenger light. The driver light should be aimed so that the light pattern on the wall is inward about 6" and slightly below the centerline of the headlight. This keeps you from blinding the oncoming cars. Disconnecting and reconnecting the headlights helps to show which headlight is shining in what direction. Reproduction headlights may shine in several directions at the same time, making it very difficult to align them if both lights are on at the same time
One Stangnetter recommends putting a fender cover over the headlight that isn't being aligned. I like his idea, it's simpler than disconnecting the lamps.
Anaconda
107
Memphis, Tn
Feb 20, 2008
#10
  • Feb 20, 2008
  • #10
Headlights look great!! What type of bulb are you using in the small light next to the headlight and wattage? I just bought the same lights for my 89, of course I want the brightest light possible. Thanks
5.0TailPipeHump
153
Feb 21, 2008
#11
  • Feb 21, 2008
  • #11
I think it might be 5 watts correct me if im wrong, the bulb is simalar to the one in your corner taillights , heres a pic of that bulb.
Thanks for the write up jrichker.
LaserSVT
3,542
233
Feb 21, 2008
#12
  • Feb 21, 2008
  • #12
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Feb 21, 2008
#13
  • Feb 21, 2008
  • #13
Looks really sharp. I love those things!
D
DanB93
66
Apr 2, 2008
#14
  • Apr 2, 2008
  • #14
Hey Tailpipehump now that you have had those lights awhile how are they? I am interested in a pair myself. What is the smaller light in the headlight? Is it a high beam or daytime running light?
5.0TailPipeHump
153
Apr 2, 2008
#15
  • Apr 2, 2008
  • #15
There not bad at all' iv yet to still get them adjusted but other than that there awsome' Id reccomend some silver stars to really light up the road with these.
The smaller light will come on when you flip your lights on ' its when i remove my ebrake handle and not flip the light switch that i only get the regular light in the housing to come on .
D
DanB93
66
Apr 3, 2008
#16
  • Apr 3, 2008
  • #16
Cool thanks
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
W
Headlights dimmer and gauges arent playing nice
  • wmfmike3
  • Aug 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
wmfmike3
W
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
