How should I tune my car as far as timing and a/f ratio. I have never changed the timing before and I can not see the number on my dampner.
I have just installed a Granitelli MAF along with 30lb injectors. When I drive first gear is kinda ok but not the same as it was. Some times it stumbles and does not want to move and then all the sudden kicks in. When I step on it (WOT) in second gear it just kinda want to hesitate. It basically want to do this all the all the gears.
Does anyone have a suggestion on what I should be doing to get it set up right. I am not sure what my fp is set at. I will have to find out. Also the timing has never been changed as far as I know. I tried to check the timing today but I can not see the numbers on the dampner. I have a timing light that I am using.
