  • 1994 - 1995 Specific Tech
Installed PMS, etc, and now got t. codes
  • Thread starter Thread starter 95 stanger
  • Start date Start date Jul 8, 2006
9
95 stanger
17
Missouri
Jul 8, 2006
  • Jul 8, 2006
I just installed an Anderson PMS, Pro-M 80mm calibrated for my 42lbs. injectors, TFS heads, Vortech V-2 and I'm fighting problems. I set up the initial program that Anderson Ford gave me for my car. I can't get it to idle below 1,000rpm (I have stock shortblock and stock cam) and it idles pretty rough. The O2 sensors are showing around .98(rich) at idle and the tail pipes are showing it with light black smoke if givin any pedal. I took the car for a drive and the check engine light came on. The codes are 124 (higher tps voltage than expected) and 157 (MAF below min. voltage). Any ideas? The tps is showing 1.06volts @ idle. It idled solid before the mods.
Redsnk95
2,243
Houston, TX
Jul 10, 2006
  • Jul 10, 2006
Do you have Idle Control On or Off?
Troy
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
R
93 LX 2.3 Trouble codes 53, 85, 21 help
  • Rickshaw302
  • Apr 15, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 18, 2025
AeroCoupe
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
