ok car drove perfect on the way to where i was working on it, i took all the dryer hose and vortech air box out.
opened the hole in the fender and got the power pipe installed.
got everything buttoned up and the car didnt run well. wouldnt idle. acted like the thottle screw wasnt holding the TB open enough. i had the battery unplugged so i took it for a short drive to see if the ECU needed to learn, i duno. car didnt get any better. would stutter and hesitate while driving, and occasionally pop when taking off.
took it back and figured the MAF wasnt working, i had to extend the harness some so maybe my wiring didnt work. i checked it an even re wired it and tested it the MAF is working.
i then got the car to idle. i had to turn the idle screw way up, its really holding the TB open its way past what it should be. i got it to idle pretty smooth, tryed rotating the MAF is changed some but it didnt help at all really.
the car smells SUPER RICH at idle. loading up harcore
i got it to idle well and took it for a drive. still stutters and pops and runs bad. a give it more pedal or WOT it wouldnt stutter.
we also noticed the car doesnt make ANY vacuum at idle, NONE, as soon as a push the clutch in to slow to a stop, once the engine idles down vacuum goes to zero, brakes get hard and engine wants to die.
we pulled over and checked vac lines, couldnt really look close but it felt like everything was plugged in, couldnt hear any hissing.
drove it back and we decided to take the vortech inlet tube out, take my MAF and filter and run the old dryerhose tube to the TB, to run the engine N/A totally bypassing the SC, to eliminate anything if it was related to the new pipe or something.
the engine N/A ran the same, still pulled no vacuum, ran rich and would rather die and stuggles to run, but there are no audible leaks, all the lines were plugged in. figured maybe a bad intake gasket but nothing happened for it to go bad.
one more thing, the vortech vent tube they have you run, from the filler neck though a filter into the airbox, since i dont have a box i let it hang down over by the fender with the filter still on so it would still vent the same.
we noticed that it pulled a slight vacumm through the tube, didnt seem right
it drove perfectly fine, when i went to start it up after the powerpipe installed and it started all this, never messed with and vac lines.
mechanically the engine is running fine, no cooling issues just runs pig rich and hesitates and mis fires under acceleration. and had to adjust my TB screw ALL the way out pretty much to get it to hold an idle and it still doesnt want to idle well.
my car never made much vacuum anyways. would pull 10 inches at idle. my cam is advanced so i duno if that would affect it at all. maybe the intake gasket was leaking and finally went real bad
just seeing if anyone had something to reccomend.
