I know when you install bigger injectors you need an adjustable fuel pressure regulator, and my question is that dont you also need a gauge so you can see how much psi you are giving it?
wyominghotwheel said:a gauge is prefered if you are going to run boost, to ensure correct pressure, but if you are just upgrading right now, you should be fine, the stock pressure regulator should handle 24#er's just fine...........hotwheels of turborides
HISSIN50 said:the computer will modify the injector pulsewidth to accomodate a bump in FP. if one raises the FP, the computer will figure it out in a little while and shorten the pulsewidth - you will be delivering the same amount of fuel (or do what it takes to get the A/F ratio back to what the puter wants).
stock injectors are good for up to around 300 HP.
Michael Yount said:Matt - is your car speed density or mass air?
Here's a book that will get you started with how the Ford electronic engine control or "computer" works. It's a "Must Have" for any serious Mustang guy.FiveLtrRiceEatr said:one more thing, and if you guys have any tips or more info for me it would be greatly appericated. I'm 16 and I know carbs and how they work. But I EFI and computers are new to me and my dad. He's taught all about carbs. But EFI we are both learning, I've been reading up on them alot so if you guys want to give me any more info I'd be great.
thanks again
matt
jrichker said:Here's a book that will get you started with how the Ford electronic engine control or "computer" works. It's a "Must Have" for any serious Mustang guy.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by Charles Probst :ISBN 0-8376-0301-3.
It's about $20 from Borders.com see http://www.amazon.com/ . Select boo...lot from it. thanks for the info matt
