Installing a ProChamber
TorchRed04GT
56
MI
I just got my prochamber in the mail and I was wondering if I need to use that flared peice of metal that goes into the driverside header? Also will I have to use it if I get the manifold stud kit from Napa?
Thanks.
TorchRed04GT said:
Did you use the stud kit from Napa too?
yes...you need the stud kit from napa...I had a prochamber on my car and had a nice leak on the driver side....I didn't feel like messing with it so I put the stock h-pipe back on...I am seriously thinking about putting the prochamber back on with the stud kit.
Thanks, I'll be sure to get them in the morning before the install.
That sleave on the left side is there so you don't have to use the stud kit. Mac added that after the complaints with older Prochambers. I didn't use the stud kit and have no leaks. I did replace the passenger side gasket just in case though. It couldn't hurt to use the stud kit anyway to be safe.
well..the prochamber I used was giving to me...U think like 2 years old and never used
so it might not have the new gasket
I just finished the installion today. I replaced the manifold studs and replaced the passenger gasket. No leaks yet.
I did run into a little problem with the driver side front o2 sensor because the wire was not lond enough. I just uncliped the harness from the plate that it was attached to and it gave me enough room for it to fit.
The thing sounds so bad ass, I don't know why I waited so long to get it I wish I would have gotten it sooner.
i had that same damn problem, i tried to un clip it but it was still about 1/4 of an inch too short, i was pissed. i had to buy another set of 02 extder's. o well it works fine now. yeah it does sound good, i really really really want to get rid of my cats. but that is a big smog no no here in CA, cant afford to get caught w/o cats. :notnice: :(
