  • 1994 - 1995 Specific Tech
installing a tri-ax
  • Thread starter Thread starter 87_GT
  • Start date Start date Jan 23, 2007
87_GT
179
tinley park, illinois
Jan 23, 2007
  • Jan 23, 2007
i just picked up a used tri-ax for $50. the guy said that it was on the car for about 50 miles before he took it out, put the stocker in and sold the car. in any case the thing looks brand new. the problem is the thing did not come with any hardware, and i thought i read somewhere that longer bolts are needed to bolt it to the tranny. is this true? also should i put some lock washers or loc-tite on them when i put it in. thanks,
Steve
94gts
873
Carmel, New York
Jan 24, 2007
  • Jan 24, 2007
if i remember correctly its metric fine thread (m8??) by 1.25" long. i dont rememeber the diameter of the bolt but i think it was called m8 but im not sure.
you dont need loctite or anything but put a bead of silicon along the base of the tranny where the shifter mounts. torque or tighten to like 15 ft lbs
87_GT
179
Jan 24, 2007
  • Jan 24, 2007
cool, thanks a lot
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Door wire harnesses 1996 GT
  • Adizzle843
  • Feb 5, 2026
SN95 4.6L Mustang Tech Feb 17, 2026
Adizzle843
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
