  • SN95 4.6L Mustang Tech
installing autometer gauges
  • Thread starter Thread starter v8powered281ci
  • Start date Start date Nov 14, 2007
V
v8powered281ci
  • Nov 14, 2007
just ordered some gauges from autometer off of ebay...air/fuel,oil pressure, and water temp. they are the lunar series and since autometer discontinued them i figured id get them while i can to match my lunar series gauge cluster as well.
now, these will be going in an 00 GT and ive never actually put in gauges before so i was wondering if anyone could lead me in the right direction on how to hook them up and the best way to run the wires. Ill have the sending units and fittings for them just need some info on how to install them. all 3 are going on the a-pillar.
thanks
N
Nightstick
68
  • Nov 14, 2007
If I remember right on a 00', the Defroster button is up next the the headlights??
You can tap off of that for your hot and ground. Id recommend fusing the hot with a 1 amp fuse. For illumination you can tap the blue/white stripe(I think) on the headlight switch. Sender wires go from gauge straight to sender. Theres a rubber plug in the fire wall under the dash next to the steering shaft to run the wires through to the engine bay.
I cut holes in the stock A-pillar cover for future access to the gauge wiring being the Autometer pod fastens right over the top of it with plastic push pins.(have to drill small holes for those). All easy just time consuming.
tank_567
731
26
29
Raleigh, Nc
Nov 14, 2007
  • Nov 14, 2007
I did the same thing on my 98 gt. It worked out great
V
v8powered281ci
  • Nov 14, 2007
after i run the wires through the firewall how do i hook them up for each gauge?
M
mineralgraygt
187
nj
Nov 14, 2007
  • Nov 14, 2007
the oil and water are easy to hook up. the water temp sensor goes in on the d/s of the block there is a bolt that goes toe coolant passage so you can drain the coolant out of the block just take that bolt out and install the sensor in the hole. the oil pressure guage i hooked up right under the oil filter. you will se there is an extra port right under the stock sensor. i used that port you can get a 90 degree adapter to hook up hook the sensor up at lowes i think its a quart inch.
V
v8powered281ci
  • Nov 14, 2007
where in nj are u from?
M
mineralgraygt
187
nj
Nov 14, 2007
  • Nov 14, 2007
im from blackwood. is this jim?
V
v8powered281ci
  • Nov 15, 2007
yea ha thats funny you are jason correct?
twogts4us
4,188
12
79
Dunedin, FL
Nov 15, 2007
  • Nov 15, 2007
Here's a couple links that'll help -
http://www.fnsweet.com/garage/gauge/index.shtml
http://www.modularfords.com/forums/showthread.php?t=34631
http://www.modularfords.com/forums/showthread.php?t=23655
V
v8powered281ci
#10
  • Nov 15, 2007
  • #10
thanks
M
mineralgraygt
187
nj
Nov 15, 2007
#11
  • Nov 15, 2007
  • #11
haha yea let me know if ya need any help
V
v8powered281ci
#12
  • Nov 15, 2007
  • #12
okk
Scorcher2005
883
South Carolina
Nov 16, 2007
#13
  • Nov 16, 2007
  • #13
Do you have a wideband control unit to hook up the air/fuel guage to?
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Electrical Oil Pressure Gauge IN Dash Cluster Unresponsive
  • Nine Finger Wrenching
  • Jan 7, 2025
Fox 5.0 Mustang Tech Jan 8, 2025
85GTStangGuy
1970 Mach 1 Fuel Gauge Issues
  • 70 Mach
  • Jun 13, 2024
2K
Classic Mustang Specific Tech Sep 1, 2024
Mach1 Driver
M
Electrical 5.0 Resto Gauge Cluster Fuel Ohms
  • sav22rem22
  • Dec 31, 2023
2K
Fox 5.0 Mustang Tech Mar 6, 2024
1everett1
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
