Installing BBK Unequal Headers?????
  • Thread starter Thread starter roadrunner19va
  • Start date Start date Feb 20, 2007
R
roadrunner19va
63
  • Feb 20, 2007
I purchased a set of BBK unequal length Headers along with stage 8 Locking bolts. What all is required when installing these. I have a 1991 Mustang with 50,000 original miles on it so motor mounts should not be sagging. Does anyone have any tips that might help me. what will I need to take off. Thanks Travis
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Feb 20, 2007
  • Feb 20, 2007
move or take off the h pipe, that helped me out a lot, then it is fairly straight forward. take off old headers, scrape off any gasket material and clean heads, then install the new, it's usually best to get the two end bolts in first then thread in the middle ones, tightening down the middle first and moving out to the outside bolts. Good luck and enjoy I used to have the bbks and are a good piece. Sound good too!
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • Feb 20, 2007
Dont use cheap gaskets or youll do this more times than you want to. Also, before you install them, line up your gaskets on the heads, and see if any trimming is required.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 20, 2007
  • Feb 20, 2007
This is a pretty standard mod. The only real advice i would give you is to soak down the studs and bolts that hold your factory headers on before you start to take them out so that none will bust on you. Remember to never sieze or copper coat your stage 8 bolts that you are using so that when it comes time to remove them it is easy.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
