installing ground effects
  • Thread starter Thread starter PeteyAce
  • Start date Start date Feb 1, 2007
PeteyAce
346
Feb 1, 2007
  • Feb 1, 2007
how do you exactly install ground effects on an lx (not the front and rear bumpers) there any drilling required and doubled sided tape?
4G-KDMP
935
CA
Feb 1, 2007
  • Feb 1, 2007
you mean like the ground effects from a GT or aftermarket ground effects?
PeteyAce
346
Feb 1, 2007
  • Feb 1, 2007
ground effects from a gt
Shauns GT
101
Brandon, Manitoba, Canada
Feb 1, 2007
  • Feb 1, 2007
Well the front and rear bumper extensions bolt on through the fender/ quarterpanel in place of the stock lx moulding. The side skirts and the front quarter panel pieces are held in place by metal brackets that are rivoted to the rocker panel and quarterpanels. If you get your body kit from a donor car take a drill or a sharp chisel and hammer and retrieve those brackets, they can be made from simple sheet metal but youll want an original or at least a pic of one to know what it looks like.
Also dont forget to get the door mouldings for the conversion as the lx mouldings dont have as wide a "stripe area" as the GT ones do. (my buddy missed that small detail doing this exact conversion)
ALMOST STOCK
1,250
41
88
CA.
Feb 1, 2007
  • Feb 1, 2007
You’ll need to attach the brackets/retainers with pop rivets and not double tape to keep them in place.
If you’re thinking about installing the GT moldings for the ground effect you mentioned; you’ll need these retainer pieces which hold the GT moldings into place.
The problem isn’t finding the Retainer’s because you can find them on Mustang Unlimited site
http://www.mustangsunlimited.com/Su...Body&subCategory=&Keywords=MU_BD&CatKey=74-01
the problem you’ll run into is finding the exact location to install the retainers.
But the again that’s just View attachment 406262
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
