Installing rear upper/lower control arms- Help!
  • Thread starter Thread starter smokinit2
  • Start date Start date Jul 12, 2006
smokinit2
22
Miami, Fla.
Jul 12, 2006
  • Jul 12, 2006
I'm replacing the stock rear upper/lower control arms with a set of Macs on a 1992 GT 5spd 5.0. Now with the Macs, it keeps eating the bushings up when the car is'nt really driven everyday nor driven hard. I'm I missing a step in the install? Help!
D
Daggar
3,902
  • Jul 12, 2006
Moved upon request of another user. You should get more responses in Tech.
fidstang
307
South Lansing
Jul 13, 2006
  • Jul 13, 2006
Which end/arms are getting ate up?
Fox_84
143
  • Jul 13, 2006
The lower control arms are to be torqued to I believe 86 ft./lbs. I would say anything just shy of 90 would be fine as they have to have a certain amount of free movement to them or if you torque them too much they bushings will be in a bind. I would say do the top somewhere very near this. You may want to use new lock nuts or a medium threadlocker to assure the nuts dont back off. If you are just tightening the control arm bolts to the max you can turn and dont stop until you cant go no more, you are binding them and this is the reason for worn out bushings. Hope this helps.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Jul 13, 2006
  • Jul 13, 2006
Are they supposed to be torqued with the weight of the car on the springs? I can't remember right now ......
FORCED2DV8
458
Grand Rapids MI
Jul 13, 2006
  • Jul 13, 2006
It doesnt matter if you tourqe these with out the weight on, If it makes you feel better put the jack stands under the axle. Use grease on the sides of the bushings, not alot just enough to allow lubrication.
V
v8only
2,378
22
49
Jul 13, 2006
  • Jul 13, 2006
yes it does, it's very important to torque the control arms with the weight of the vehicle on them. Support the rear, and let the weight rest on the rear, then torque it.
Mac has those poly bushings at both ends. this creates a lot of bind around corners, and wreaks hell on your torque boxes. May even be the source of some of your wear.
if you're ever in the market, get a set with a spherical bushing at one end, and poly at the other end, and you'll be good for the twisties again
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
Suspension Rear pinion angle
  • JD1964
  • Apr 30, 2025
Fox 5.0 Mustang Tech May 5, 2025
JD1964
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
