Installing Struts
  • Thread starter Thread starter 90blue5.0
  • Start date Start date Mar 29, 2008
9
90blue5.0
266
Regina, Canada
Mar 29, 2008
  • Mar 29, 2008
I'm installing new struts and am haveing some difficulty tightening the strut piston nut on the upper strut mount. Are there any tips/tricks to stop the piston from turning as I tighten this nut?????
68stang351
850
9
39
Savoy TX
Mar 29, 2008
  • Mar 29, 2008
Is it because the shaft is turning too when you try to tighten it? If it is (I had the same problem), you can take a large flathead screwdriver and stick in the slot on top of the shaft to hold it still and tighten the nut with a wrench. I had to do that on both my 90 and my 04.
white_97_GT
76
Ontario, Canada
Mar 29, 2008
  • Mar 29, 2008
there is usually 2 flats on the sides of the top for holding with a wrench...or like the above mentioned slot
HISSIN50
34
129
Mar 29, 2008
  • Mar 29, 2008
Shocks have flats and the struts have slots. I use a leverage-bar to hold the strut via the slot.
Good luck.
white_97_GT
76
Ontario, Canada
Mar 29, 2008
  • Mar 29, 2008
my struts have flats...strange 10 ways
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
Mar 30, 2008
  • Mar 30, 2008
I just used my Impact Gun on it with the Car on the Ground.
Cobra912
1,777
11
39
Wish I was anywhere but here
Mar 30, 2008
  • Mar 30, 2008
I just put in my flaming river rack, steering shaft, lakewood 70/30's and hotchkis C+C plates tonight.
The strut part was easy. Crescent wrench to hold the top of strut in position and I believe a 24mm wrench to tighten on the nut.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Suspension UPR Coilover sleeve dosent drop down over strut
  • Creomod
  • May 25, 2025
Fox 5.0 Mustang Tech May 28, 2025
RaggedGT
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
