Installing Subframe conn on 87 Convertable
  • Thread starter Thread starter Ted87GT
  • Start date Start date Nov 5, 2004
T
Ted87GT
58
Southern Maine
Nov 5, 2004
  • Nov 5, 2004
I am thinking about full length, welded, subframe connectors for my 87 GT convertable. Anyone installed these themselves? I can weld, so no problem with that part. I looked under the car last night to check out the stock braces that the 'verts come with. They're - pop rivited. Yikes, what where those Ford engineers thinking! There also were some black plates (not a good description, but they were basically flat) that were bolted to the pop-rivited braces and to somewhere towards the center of the car. I didn't jack the car up so I couldn't see exactly where.
Do the existing braces make it real difficult to install subframes? Do I weld in the exisitng braces or ditch them? I was expecting the pop-rivited braces as I have heard about them, but I was surprised about the other bracing. Do they stay or go?
Any info, tips, war stories, etc appreciated!
Ted senior (my son uses this ID too)
7upstang
75
Calgary, Alberta
Nov 5, 2004
  • Nov 5, 2004
Usually, the ford bracing goes when you weld in aftermarket subs. The pop rivet stuff doesn't really do anything to help stiffen the car anyway.
The subs I use are the Western motorsports tubular subframes. They are very stiff and virtually indestructable.
http://www.cardomain.com/id/uncola
I didn't weld them on myself, so I don't know how difficult they were to install.
www.wmsracing.com Here is the link to western motorsports
http://www.wmsracing.com/pgi-ProductSpec?WMS-SFC79M and here is the link to subframes themselves
P
PonyBoy90
555
Toronto
Nov 5, 2004
  • Nov 5, 2004
You can weld them in yourself, just make sure your car is properly supported before you tack them on. If you have the car in the air, you have to make sure your frame is straight as if all 4 wheels were on the ground.
I've heard of some guys putting their foxbodies up on a lift, welding the subframes on, only to find that when they put the car back on the floor and tried to open one of the doors, they couldn't! Yikes !
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 6, 2004
  • Nov 6, 2004
Support the car on jack stands uner the rear axles and front A-arms, that way it will sit on the stands like it does on the ground. You have to drill out the rivets and remove the factory braces. You can trim the braces and weld them back in after the subs if you want, but I didn't. The braces you mention are two "V" shaped round tube braces flattened on the ends and the top of the V. The V tops of both bolt to the K memeber and run forward to the radiator brace and rearward to the area of the riveted chassis braces.
87TTopGT
173
  • Nov 7, 2004
I would recommend the Maximum Motorsports subs, they come with various reinforcements that weld in and really make a nice package when you're done. I'm sure my T-top was as floppy as your vert before I had mine installed, you won't believe the difference!
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Nov 7, 2004
  • Nov 7, 2004
Full lengths you'll have to grind off part of some chassis bracing that's already there. Just the lip part of it, though, nothing major. Took about 10 minutes on mine.
HISSIN50
34
129
Nov 7, 2004
  • Nov 7, 2004
Dave, i thought you once posted something negative about having subs installed (something about the ride quality or something)? is that right, or am i off base as usual?
Ozz
3,514
66
109
Canton, MI
Nov 7, 2004
  • Nov 7, 2004
No complaints from me,. There's just a little more to the story, that's all.
I'd installed Bilstein HD struts & shocks before I got around to doing the SFCs. The Bilsteins are very stiff and provided great, tight ride quality. When I put the SFCs in, the difference wasn't as great as it would've been had I still had a weak suspension. I could still tell a difference but it wasn't "day and night" like it would've been without the Bilsteins.
HISSIN50
34
129
Nov 7, 2004
  • Nov 7, 2004
ooops. my bad Dave.
thanks for the clarification. when i was reading sub frame threads once, i thought i remembered something from you indicating lackluster results. obviously i remembered somewhat correctly but completely wrong. LOL.
thanks again.
Ozz
3,514
66
109
Canton, MI
Nov 7, 2004
#10
  • Nov 7, 2004
  • #10
No prob
I might have said before that I rather would not have gone through the whole installation - I had to pay for the welding as well as take quite a trip to/from the shop because no one in my area did I trust w/my car. That totalled out quite high.
Without the stiff Bilsteins, the improvement over non-braced cars will be great. Bilsteins are just that good!
HISSIN50
34
129
Nov 7, 2004
#11
  • Nov 7, 2004
  • #11
mansonozz said:
No prob
wow, glowing recommendation on the Bils.
must be nice to have resources to pamper the S.C. as you do.
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
