  • SN95 4.6L Mustang Tech
installing subframes, how hard is it?
  • Thread starter Thread starter Black2K1
  • Start date Start date Mar 2, 2004
Black2K1
88
Raleigh, NC
Mar 2, 2004
  • Mar 2, 2004
Has anyone installed subframes on their own? I really need to get some soon and planned to do the install myself. I am looking at the steeda full length subframes. Is the install as simple as it looks?
Beau
3,050
San Diego
Mar 2, 2004
  • Mar 2, 2004
do you know how to weld? if not then you won't be able to install the best ones. bolt on subs blow.
Bone Racing
1,075
Long Island, NY
Mar 2, 2004
  • Mar 2, 2004
welding is the hardest part
T
TopEndTurboDSM
columbia, MD
Mar 2, 2004
  • Mar 2, 2004
well if your replacing with a stock one youll need an engine support or you can take it out how we do at work(youll need a lift for this way): disconnect all connectors vacuum lines going to the fire wall as well as the fuel lines, unbolt the struts and by now you shouldsupport the engine with a table top and the trans unbolted from the support(obviously now the driveshaft should off) with 4 13min I think, then unbolt the sub frame bolts 21mm I think, and lower the trans/engine down and crane the engine off the frame and wahlah your rdy. Other than that Youll have to support the engine. Goodluck
Andrew
Y
YtnGT
202
TX
Mar 2, 2004
  • Mar 2, 2004
I decided to save 50-100 dollars and weld my steeda SFCs on the stang.
If I had it to do all over again, I would take it to a local muffler shop that does good work.
I actually enjoy welding and it was still a PITA.
If you are going to do it yourself... get the car as high off the ground as possible, believe me.
BTW I used a Lincoln weld pak-100 (88A) with flux core wire.
ghost4.6
63
  • Mar 2, 2004
Andrew
he talking about sub frame connectors not a k-member
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
Mar 2, 2004
  • Mar 2, 2004
Andrew
WTF?
drunk post?
D
Daves4.6GT
163
  • Mar 3, 2004
Andrew
woah! I think hes in the wrong Thread............My subframes were very easy, they sliped up and fit perfect, and welded them up, no problems. just make sure you dont jack it up from the Axle the subframes wont be set up right....
Dave
T
TopEndTurboDSM
columbia, MD
Mar 3, 2004
  • Mar 3, 2004
Dave
Im retarded...I was thinking the k frame was the subframe...Im so used to doing windbags that I call it that at work. Well if you need to replace your k member thetre ya go.
Andrew
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
How to Route Subframe-Style Intermediate Brake Line?
  • cnorman31
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 29, 2025
cnorman31
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
9
New from northern MN
  • 91firecracker
  • Apr 19, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2026
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
