Installing System. Fuse ?
Five04sho
11
Hey, I have a 92 2.3L Stang and ive wired myself up a system. I want to run the remote wire into the fuse panel. Which fuse in there is only powered with the ignition on? Thanks in advance!
Why Do you want to run the Remote to a Powered wire?? The Remote is Intended to be hooked up to an Amp/Eq to turn them on. Hooking the remote up to power would likely damage the Headunit, You should hook the Yellow up to a constant (always on) and the Red up to a switched power lead (assuming your radio goes by the color standards. Both of those wires can be found behind the Old factory radio.
Dr.
Ditto what the Doc said.
If you've taken the time to put the system in the car, then it only benefits you to do it right. On aftermarket head units there's a blue wire labled either Remote or Power Antenna that is used to turn on amps, crossovers, EQs etc. This way they only come on when the head unit is on.
