Installing T5...quick question
  • Thread starter Thread starter 5.0 Nostalgia
  • Start date Start date Jan 1, 2005
5.0 Nostalgia
904
CT
Jan 1, 2005
  • Jan 1, 2005
I am putting the t5 back in my car. I have one quick question. Does the input shaft need to be greased? I can't remember if I did that last time.
D
Daggar
3,902
  • Jan 1, 2005
There should be a light coat of grease on the bearing retainer shaft. I've also put a light film on the splines before. That part did not seem to make any difference one way or the other. I suppose it might help with installation just a hair.
HISSIN50
34
129
Jan 1, 2005
  • Jan 1, 2005
i like to put a thin film of grease on it.
good luck.
5.0 Nostalgia
904
CT
Jan 1, 2005
  • Jan 1, 2005
Thanks for the fast reply. I want to do this today because it is almost 60* outside. I was thinking of putting a light coat on the splines. I am going to have someone turn the slip yoke to help line the input shaft up.
5.0 Nostalgia
904
CT
Jan 1, 2005
  • Jan 1, 2005
Also, there's a couple of marks on the input shaft bearing. Is that ok?
5.0 Nostalgia
904
CT
Jan 1, 2005
  • Jan 1, 2005
Now I have a couple questions. I tried putting it in and it doesn't look like the throwout bearing is lined up with the clutch (about half inch to the right of it). Do I have to take the bellhousing off and line it back up or can I just try again. I don't want to take all the back off again.
HISSIN50
34
129
Jan 1, 2005
  • Jan 1, 2005
if you mean the pilot bearing, that is normal. people use the divots to grab onto the bearing to remove it.
5.0 Nostalgia
904
CT
Jan 2, 2005
  • Jan 2, 2005
Thanks. I figured out what I have to do.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
T5 identification
  • 3054tony
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
AeroCoupe
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
