Installing Timing tape.
  • Thread starter Thread starter BC_Ace
  • Start date Start date Jul 9, 2004
BC_Ace
140
Vancouver
Jul 9, 2004
  • Jul 9, 2004
I think my outer harmonic balancer has moved a bit over the years on my 289, causing the timing mark to be off. I bought some timing tape and was wondering what the most accurate way of determining my exact tdc is.
67bluestang
193
Tucson, Arizona
Jul 9, 2004
  • Jul 9, 2004
If you think the balancer has moved, i'd just replace it.
TDC can be a pain to find with the engine in the car. You need a positive stop to screw into the spark plug hole. Rotate the engine by hand until it comes up against the stop and mark the balancer at the timing pointer. Rotate the engine the other way until it comes up against the stop and mark the balancer again. Then measure half way between the 2 scribe marks and that is TDC.
SadbutTrue
2,391
Thousand Oaks, California
Jul 12, 2004
  • Jul 12, 2004
As far as timing tape goes... I think i need to install some because I need to measure my total timing and the marks on my balancer don't go all the way to 40 degrees...
A few questions... what is the diameter of a 69 351w's stock harmonic balancer? If I jsut wanted to tune it, could I save a few bucks and use some masking tape + a sharpie to make some ghetto timing tape that extends to 45 or so degrees (just use the same spacing as the marks that are on there) and go by that?
67GTA-FB429
777
Tri-Cities, Wa
Jul 12, 2004
  • Jul 12, 2004
It is a linear distance. Just measure and mark from 30. I did this yesterday, but I did not need the ghetto masking tape, I ust made marks on the balancer with a sharpie.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 5 6 7
3K
Classic Mustang Specific Tech Yesterday at 3:56 PM
horse sence
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
