Installing wheel studs
  • Thread starter Thread starter Baaah
  • Start date Start date Mar 28, 2004
Baaah
262
West Springfield, MA
Mar 28, 2004
  • Mar 28, 2004
What would it take to install longer studs on a 65 mustang? The stock ones are too short to safely bolt my wheel adapters onto, so i need to put longer ones in both the front and rear. Will I have to drain the rear end or can i just pull the axles out a few inches without losing my fluid. And how do I go about doing the fronts.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Mar 29, 2004
  • Mar 29, 2004
Both front and rear are pressed in.
Remove the axles and front Hub's and take them to a machine shop with a press, It's worth the few bucks not to have to beat them out and reset them.
No you won't leak rear oil, just becareful of the seals.
PB
Baaah
262
Mar 29, 2004
  • Mar 29, 2004
So i can take the axles completely out and i won't have to worry about gear lube coming out?
1969mach1351
285
Sacramento, CA
Mar 29, 2004
  • Mar 29, 2004
That's correct.
pabear89
2,126
Mar 29, 2004
  • Mar 29, 2004
Just a small amount will leak from the tube ends.
use care not to drop the axle onto the seal and smash it.
PB
Baaah
262
Mar 29, 2004
  • Mar 29, 2004
Alright, great. Now i was looking at some pics of the fronts since I'm about 50 miles from my car right now, and i thought i noticed that the studs are pressed into the actual drum cover. Is this correct? If so, that'd be much easier than i had originally planned.
Baaah
262
Mar 29, 2004
  • Mar 29, 2004
Ok, one more question...What size is the knurl on the studs for the front and rear drums. Summit sells two sizes of ARP studs for mustangs, .618 and .625.
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech 2 minutes ago
horse sence
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
