instrument cluster swap, will it work?
1fastsn95
122
Carthage, tn
ok the instrument cluster in my 87 is in sad shape. Looks like it sat in the sun for years. The numbers are faded and cracked and just look bad. I found an 89 (85mph speedo) 4cyl at the junkyard with a perfect cluster. Can I simply swap them out? Plug and play?? Thanks!!
He has an 87.
Yeah, you'll be fine. I just changed mine today actually (from the 85 MPH to the 140 MPH). Pretty simple, get to the cluster, take it out, and there will be 3 things to unplug. Two wire clusters, one on each side, and the speedo connector. Then just switch it out and put everything back together.
