instrument guages
myboyhasa66
81
1)how do you take out the guage cluster ina 91. the chilton says to take out the side switches but i can't figure out how.
2) i put on my af guage and the only thing that happens is there is one rich led that turns on and it doesnt change. the ground and illumination are good and the signal comes from the pin on the la3. has anyone had this problem
jzleach1
535
Westminster, Maryland
1) The back of the switches should be held in by a "push" style connector. Try using a small flat bladed screwdriver to press in these tabs and the switch should pull straight out.
2) Check your connection. Most folks hook them up at the O2 sensor, not the ECU.
