intake and head runners
  • Thread starter Thread starter 5.0TailPipeHump
  • Start date Start date Apr 30, 2009
5.0TailPipeHump
153
Apr 30, 2009
  • Apr 30, 2009
My intake runners on my gt40 lower are so small compared to my head runners on my gt40x heads' should i just go ahead and port these out or find another intake ' im at aloss and don't know what route to go' any suggestions.
gt40 lower# rf-f87e
9k461-ba
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Apr 30, 2009
  • Apr 30, 2009
Your not going to find anything to match it EXACTLY. It wouldnt make a HUGE difference if you just matched the ports (especially because your heads are bigger than your intake). You would only REALLY benefit if the whole intake was ported, because even if you open up the ports to match the heads, the inside of the intake is still going to be the same size. You can spend half a grand and get a bigger intake, or just stick with the gt40 which has been proven to flow good over 350hp. Or just get it fully ported by tmoss or something.
You can get some better input from tmoss though.
5.0TailPipeHump
153
May 1, 2009
  • May 1, 2009
I don't think ill be pushing over 300 hp' right now my combo consists of an anderson ford motorsports cam N21 gt40x heads along with a cobra upper and lower , would it be safe to stay with this intake or would it be starving the motor for more air ' would i benifit any horse power if i get a bigger intake to match up my head runners.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
May 1, 2009
  • May 1, 2009
Take the heads and intake to a good head/machine shop.
A place that does it right will mock up the heads and intake and use a scribe to mark out and port the heads to match the intake (or vice versa). They should valve job the heads while they are at it, as much as i like gt40x heads, their factory valve job leaves quite a bit to be desired.
You can make some noticeable extra hp with this work. Figure on blowing about $350 or so.
95-early 97 Explorer upper and lower intake manifold - NO LONGER NEEDED
  • R82148V
  • Jul 11, 2025
  • Want to Buy
Want to Buy Oct 31, 2025
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Help with gaskets
  • bhackney
  • Jan 7, 2024
Fox 5.0 Mustang Tech Jan 7, 2024
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
