intake change ????s
  • Thread starter Thread starter slow93
  • Start date Start date Sep 30, 2005
slow93
406
  • Sep 30, 2005
i just got done switching my intake and i have a massive vacuum leak and cant find where it is coming from exactly.it is whistling pretty loud but i cant pinpoint it.it seems to be coming from close to the TB or egr spacer but i can feel and leak when i feel around them.what are the more common places that it could be leaking from?
slow93
406
  • Sep 30, 2005
come on,i know im not the only one who has ever had this problem.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Sep 30, 2005
  • Sep 30, 2005
it could be leaking from the head / lower manifold area. Put some soapy water around there and see what happens.
mrswivlepants
93
  • Sep 30, 2005
Brake clean is also a good way to pinpoint vacuum leaks. Spray it all over the place and when you hear the engine surge you've found your leak. The brake clean is flammable so when it gets sucked in the leak the engine has an added combustible source, hence the surge. Sometimes the surge isn't such a surge so a pal watching your Tach might be helpful to figure out when it's actually "surging."
old_blue
1,783
282
124
Sep 30, 2005
  • Sep 30, 2005
pcv will pop out sometimes on new intake installs when you use the old pcv setup. Check there and if it is popping out go to Ford and get a whole new pcv kit, (screen, grommet, valve)
S_Charged306LX
196
South Florida
Sep 30, 2005
  • Sep 30, 2005
large intake leaks that i have encountered were: gasket between upper and lower intake cocked to the side causing whistling it was crazy loud, vacuum tee on drivers side firewall, fuel press regulator vacuum hose. if you spray brake parts cleaner on suspected area and the engine bogs or dies you found your leak, and that goes for any vacuum leak cause brake parts cleaner acts like more fuel entering the engine.
M
MatthewP
355
Calgary, Alberta
Sep 30, 2005
  • Sep 30, 2005
Sometime the membrane in the EGR valve breaks too. Pull the vacuum line off the EGR valve and plug it to check. Everyone else mentioned most of the other places.
-Matthew
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
