Okay, I'm runnig a 351W. I just recently (finally) got it running right by just buying a new carb. The thing is, it likes to stall in gear at idle. Even when warm it will sometimes do it. It seems like the vacuum is marginal when at idle in gear. The cam isn't too big.....should idle pretty well, more of a torque cam.
Anyway, today I was dicking around trying to test my theory about the unhealthy idle being ralted to vacuum. I know there are no leaks; so, I started testing some things.
-- Both of my breathers are connected to a vacuum source. One is connected to the base of the air cleaner. The other is connected to FULL VACUUM at the manifold! Is this appropriate?
While it was idling, I clamped the FULL VACUUM hose off completely. The revs immediately dropped from 1000 rpm to 700 rpm (very significant drop due to less air available). Is this normal?? What would happen if I only let the one breather stay connected to the cleaner base and just let the other one vent down and away from the engine?? Wouldn't this tend to allow me to tune the carb much better and smooth out the idle??
I know this is long; but, I am sure someone knows what I'm talking about and can give me an education on this one. Also, how much venting should the crankcase be doing through the breather....at idle? witha litle rev?? I can see obvious smoke coming out, even at idle? Worn rings??
My corvette doesn't even have a vent on the valve covers for venting crankcase gasses?? The only vacuum connection is to the timing advance.
Some well into the million mile + before a rebuild.
